Unreal Engine 5 Powered EzBench Benchmark
Permabanned
31 Aug 2013
Scotland
From - https://wccftech.com/unreal-engine-...hrough-its-paces-with-8k-textures-raytracing/
There's a new benchmark in town known as EzBench which lets you test your graphics card in Unreal Engine 5 with high-res textures & Raytracing.
Unreal Engine 5 Powered EzBench Benchmark Will Make Even The Fastest Graphics Cards From AMD & NVIDIA Sweat​
Developed by Eztheory AS, EzBench is a free benchmarking tool that is based on the next-gen Unreal Engine 5. It makes use of a range of high-quality assets which feature 8K textures & also adds raytracing support. According to the developers, EzBench is simply a stress test and does represent the worst-case scenario for Unreal Engine 5 apps. The devs state that users should be expecting much higher frame rates in games that are optimized around the engine.
The benchmark is recommended to run on a modern PC with either a high-end Radeon RX 6000 or NVIDIA GeForce RTX 20 or higher graphics card considering the use of raytracing. Older GPUs can run the benchmark but considering the amount of stress this tool puts on high-end GPUs, you can only pray that your graphics card can deliver over double-digit frame rates.
The benchmark can be downloaded from Steam and weighs in at around 20 GB due to the use of higher-res textures. The developers themselves scored 32,620 points with an average frame rate of 39.904 FPS using an NVIDIA GeForce RTX 3090 graphics card.
Listed under Steam as EzBench Benchmark or https://store.steampowered.com/app/770170/EzBench_Benchmark/
Edit - Just noticed it's already been posted.
