Unreal Tournament 2004
18 Sep 2003
Just a quick one, is it ok to buy this game 2nd hand or does it use a similar CD key system to half life 2? Once it's been registered can it be played by someone else?
Cheers.
Will be fine mate.
At times I've had 5 people playing online on my CD key many years ago all on one server before I made them buy there own copies :p
Not even sure if the game has cd-key bans. Its certainly nothing like steam!
Yeah you should be fine..
Just in case you don't know.....
If you have a 8 series card and running XP, you might get stuttering and poor perfomace in UT2004. It's a common problem, but with Vista it works flawlessly, its a driver issue that nvidia haven't seem to fix for XP. I have this problem with XP, but not in Vista.
