Unreal Tournament 3 error
Suspended
30 Aug 2004
Since going from X1800XT to 8800GT I get this error
'AppName: ut3.exe AppVer: 0.0.0.0 ModName: ct_oal.dll
ModVer: 5.12.1.441 Offset: 00010636'
What I have found is this
http://utforums.epicgames.com/archive/index.php?t-590379.html
So, do you think i should try this first?
In the utengine.ini set the following values:
Under [Engine.ISVHacks]
set: DisableATITextureFilterOptimizationChecks=False
set: bInitializeShadersOnDemand=True
set: PumpWindowMessagesWhenRenderThreadStalled=True
There is a beta driver for nvidia cards that are basically the same as the current release driver except the beta has fixes for UT3 only.
Thats an OpenAL error. Try turning off hardware sound in UT3.
strange. Worked fine before when i had my X1800XT in. One thing that i did do was move my audigy2zs from one pci slot to another.
I'll try moving it back tonight, but im sure its a graphics thing rather than sound
