Unsecured network - safe to connect to?
2 Aug 2005
Some hotels have free wireless internet access, they say it's totally free but unsecure. Is this normally safe to use? Normal applications we would use it for are email, web and Skype. Any advice appreciated :)
As long as you have a good software firewall running and have no unsecured shared folders it'll be fine IMO :)
It just means that the data transmitted from your laptop to the wireless access point is unencrypted, yes someone with the right equipment and knowhow could intercept "packet sniff" your data that you're sending/receiving but it's highly unlikely.
being petty I would untick the file and print sharing exceptions on the windows firewall. And make sure you have anti-virus software which is up to date :)
The hotel probably has a router and your going to be on there LAN so its probably some basic screening because of the NAT used on most routers BUT you should assume the worst and get better protection.
You should have all the XP and applications security updates installed
AND a good antivirus/antispyware packge running
AND a software firewall able to keep better tabs on incoming and outgoing data
As noted already be sure shared folders etc are locked down.
theMAD2 said:
Thanks for the advice mate, we're just running XP pro with XP firewall, would you say this is good enough?
I would think so, I use it fine on my lappy, however someone may suggest something else :)
Keep your Windows updates, AV and Spyware upto date also.
Edit: beaten to it!
