For the past 12 weeks, my internet has been very unstable. I decided to find out why, and rang my ISP (ADSL24), and they detected an error on the line, and advised me to contact BT. I did so, they asked me to plug a phone into the test socket and listen for a dial tone, there was none. The technician said that the problem is in the phone line, and sent out an engineer to fix it. He put in a new wire that goes from the street to my house, and now i get a dial tone. I figured this would fix it, and he went home at around 5pm yesterday evening, he's sending round another engineer to tidy up the wiring in the next 24 hours, so essentially, the new wiring is done. However I'm still getting disconnects on my line. So i tried yet another new router, new microfilter etc, and it's still unstable. Sometimes, every few minutes the router loses sync with the exchange, then reconnects, sometimes it will last a few hours.
Downstream Rate: 284 Kbps
Upstream Rate: 445 Kbps
Downstream Margin: 31 db
Upstream Margin: 23 db
Downstream Line Attenuation: 24
Upstream Line Attenuation: 13
Those are my router stats at the moment.
I have actually exhausted all options, it's definitely a problem between the BT faceplate and the exchange, but i can't figure out what. Could ADSL2+ be contributing to the problem, which I upgraded to for no extra cost a while back. Back when i was on normal ADSL, it was stable for over a year, i didn't notice even one disconnect.
