Hey all,
after digging through google can't seem to find anything that'll help me with this so, here goes.
PC spec:
E5200
Radeon 4850
EP43-DS3L
I upgraded RAM from some 2GB stuff to this https://www.overclockers.co.uk/showproduct.php?prodid=MY-039-KS
And at the same time installed Win7 64bit, now that ram runs at a default of 800mhz, but is designed to be clocked to 1066mhz, so I did,
Upped the DRAM Voltage to 2.2 like it says, tighten the times to 5-5-5-15 as it says it's been test at.
Since then I've been running it, it boots and posts fine, but some strange things are happening.
1) A game (Guild Wars) loves crashing, but only when its minimized, it seems if I minimize it then do something else, it'll crash in a few seconds/minutes.
2) I also got a BSOD a few hours ago, wasn't doing anything intensive and was only using 50%~ of the RAM.
Is it possible that my CPU became unstable, my old ram which was 667, was OC'd to 800mz, which put my CPU at (if I remember correctly) 3.2GHz and is now at 3.33Ghz (temps look fine too)
Uploaded my screens of my BIOS, hopefully they'll help. (Follow the link to the gallery)
http://img517.imageshack.us/gal.php?g=13022010186.jpg
I can also upload the crash log of that game if that helps anyone.
Thanks in advance for any help guys.
PC spec:
E5200
Radeon 4850
EP43-DS3L
