Ok heres my problem, sometimes I can get my CPU to 3.2 (Specs below) and its fully stable, and sometimes Ill set it to the same speed, and the system will start, POST, reboot and come up with default clock settings. The wierd part is that if it does get to windows with the OC its totally fine, Prime tested for hours, temps all about 40-45°c.
This is the setup anyway:
Q6600 G0
Gigabyte P35 S3G
2GB OCZ PC8000
2x1GB Cheapo PC6400
Radeon 4850 512mb
Hiper Type-R 580W
Water loop of Laing D4, D-tek Fuzion and 1 120mm fan on a 3 fan Rad.
1 120mm case fan
Speedfan is reporting the rails to be running at:
+12v = 12.29v
+5v = 5.08v
+3.3v = 3.39v
I should add, I have turned off detect legacy USB devices already. Come to think of it the problem used to happen if I had my external USB HDD plugged in, and removing it would let the OC become stable.
I am wondering now if the fairly recently installed water loop is sucking too much power for the PSU. Its a decent PSU but only 580W which these days isnt that great I suppose.
Q6600 G0
Gigabyte P35 S3G
2GB OCZ PC8000
2x1GB Cheapo PC6400
Radeon 4850 512mb
Hiper Type-R 580W
1 120mm case fan
+12v = 12.29v
+5v = 5.08v
+3.3v = 3.39v
) but it happens now wether the drive is there or not, and also when the legacy storage device detect is off in the BIOS. Anyway I just did as cje suggested and upped the FSB to 1600 and dropped the multi to 8 and without wanting to speak too soon, it seems stable.
