Hello I'm after a little help and I'm hoping this is the right place for it.
I don't know a great amount about hardware but over the past few weeks with help from a friend of a friend I came up with this:
Intel Core i5-3570K 3.4GHz Quad-Core Processor £161.99
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler £23.98
ASRock Z77 Extreme4 ATX LGA1155 Motherboard £91.80
Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory £61.38
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive £41.99
MSI GeForce GTX 760 2GB Video Card £198.91
Corsair 300R ATX Mid Tower Case £59.90
Corsair CX 600W 80 PLUS Bronze Certified ATX12V Power Supply £54.68
Lite-On iHAS124-04 DVD/CD Writer £13.15
Total: £708.78
I'm trying to keep it as close to £700 as possible with the best performance for games. How does this spec look? Is the CPU fan needed? Should I add a 140mm case fan?
The only real thing I'm unsure about is the 760 and if I should pay the extra for a 770? But I guess I'm looking near £800 then... Also it shows the system estimated wattage as 356... would the power supply at 600w be good enough? As I'm yet to connect keyboard, mouse, monitor etc.
Thanks in advance
Total: £708.78
Thanks in advance
