unsure about water
14 Dec 2003
london
hi
im using a tuniq tower atm and getting decent results but id like to push things further , im on max 50 degrees atm
how much will water make to my temps thx
Indeed, under orthos small FFTs I peak at around 68, so I'll be investigating the water as soon as I can afford it as I think I've reached the limit of what I can do on air. You still have a fair old bit of wiggle room in there though, use it ;)
Unless you're in 3-figures under load, stop worrying. The latest Intel CPUs are designed to run quite happily at 90C+ and your motherboard is rated to at least 65C (Intel Thermal Design Specification) so don't worry.
