- 19 Nov 2011
Hi all,
This may seem like a noob question, and maybe it is But I can assure you I have hunted so many places, and I can't find anything which is directly related to my chip, so sorry in advance if I have missed anything.
Anyway, to the crazy story of Russell664's Desktop...
I have had my Haswell i5 4670k in two z87 boards so far, the last one being an Asrock extreme 6 z87, however, I decided to upgrade to a new board in preparation to building my brother a new system.
However, the voltages I used to run was a fully stable 4.4ghz @1.310 Vcore on the z87 boards.
The z97 will not play ball @4.4ghz on this voltage. I have read reviews about and they too mentioned about z97 needing the Vcore higher for older haswell chip, but the temperature where much lower than those of z87.
Now I have tried voltages from 1.360 Vcore all the way to 3.9 Vcore for a 4.6GHZ overclock, of which I end up with BSOD's with x124, more Vcore.
I really wanted to pull of a 4.6GHZ overclock with my H100i as I know I could cool the chip with that with not problems.
My motherboard is a MSI Gaming 7 Z97. I have to say the BIOS is far different to Gigabyte or Asrock, but i think I'm getting the hang of what is what, currently I'm at work, but if it helps I can provide some screenshots of my settings.
Just for reference I have tried my RAM @1333mhz, which was actually more unstable that it @2400mhz, which to me makes little sense. I have been hatching at this for about 4 days now and it's starting to annoy me.
What could be causing all this, or is there maybe a setting I have missed?
In regards to the power limits on the CPU, I have turned them all the way up which I should be able to confirm in a screenshot later.
Oh and my specs are:
1x Kingston 120GB SSD
1x WD Green 1TB HDD
1x WD Green 2TB HDD
i5 4670K
MSI Z97 Gaming 7
16GB RAM (Avexir and Team Group, however the are exactly the same CAS 10-11-11-31 @2400mhz settings, and my PC still did this before I got the new modules, actually since I get them it appears to be crashing less, I have also done memtest to confirm all is good)
2x Gigabyte 270x's
750w Corsair RM Series PSU
I used to do F@H 24/7 on my system and i wish to do it again, I just need to sort out this damn overclock. I have noticed a huge difference in frames on some games @4.4GHZ or above so I would like to try and achieve something like that.
Thanks again for any help in advance.
Currently i'm at a loss, I just wanna play Titanfall
1x WD Green 1TB HDD
1x WD Green 2TB HDD
i5 4670K
MSI Z97 Gaming 7
2x Gigabyte 270x's
