Unsure what to do for cooker splashback?
20 Oct 2002
London
We're locked in with our new kitchen design, waiting on the builder to remove the walls, insulate, new windows go in first before we can get it installed. Probably looking at January now I guess :(
But we're unsure what to put as a splashback. To make it seem more spacious we've opted for no cupboards around the cooker (it's 900mm wide range). Initially as you can see from the render I was set on brick slip tiles (ignore the colour, they would have been more subtle and matching London yellow brick). But we've gone off that idea, and also it's not great for cleaning directly behind the cooker. We're thinking a more subtle "grungey" white brick effect behind the whole cooker wall area, but again that would be annoyingly hard to clean behind the cooker so we'd want something else there. I see people use their quartz/marble worktops behind the cooker area but that only works as a whole if you're got cupboards - otherwise it's a massive expanse of quartz which looks silly. So we probably need the white brick tiles behind the whole area, and something more easy to clean directly between the cooker and hood? :confused:
The windows will be black metal framed per my Photoshop skills on the middle pic, and on the right side we've put another unit next to the boiler unit, and made the side window much smaller. All in all it's a lot brighter than the render shows, it's south facing and we now have a lovely big velux in the roof too. Units are British racing green, and brass handles/furniture/tap.
Colour of your choice glass splashback, we have black and cleans well :cool:
I was thinking white brick effect all around and glass over the top behind the cooker. But my other half really doesn't like the idea of glass, thinks it looks cheap? :confused:
I like white brick tiles, but perhaps that’s old hat now. Not that hard to clean really.
To be clear, I'm talking about something like this. Not glossy bathroom-style metro tiles. So I'd imagine as they're rough they'll be pretty damn hard to clean :confused:
EDIT: If there's any worktop left from the cutting we're hoping to get a small upstand all the way around too (up to the bottom of the windows preferably). So there's that to bear in mind.
Stainless steel won't really go - considering the cooker is black with brass knobs, and our taps, handles and plug sockets will all be brass :o
Unrelated to the splash back, but I'd get rid of the windowsills and have the worktops level and extending all the way back. give you a much better feel and more useful room.
I like that idea. Just had a look at our kitchen and it would be relatively simple to extend the granite when/if we get a new kitchen fitted.
Go for. Brass or copper plate?
And you can just call me Donald J Trump, yes? :p;)
It's not a bad idea but our windows are getting installed in two weeks! We would have had to build them taller to come down to the worktop. I quite like the window sill to put plants on etc to be fair :)
I'm still leaning towards grungey white bricks across the whole wall, with a square glass plate directly behind the cooker for cleanliness. Can anyone find a decent pic of that perhaps? :p
Shame more light is hard to come by so its a great bonus. See the second picture you can still have plants. :D
Not as expensive as you might think. I’m always surprised that people “cut corners” on the most used, longest lived, biggest value add room in the house. You could have a real focal point /statement piece. That said, budgets need to be met.
Stainless steel or glass. Anything else you'll just be cursing in a few years time trying to get the splashes of tomato off the wall.
@Pentland not the best worded post tbh. We’re certainly not cutting corners (merely working to a budget like everyone) and I wasn’t insinuating the cost would put me off. I was only joking that a brass/gold splash back might look a little blingy.
Anyhoo, our matte black/graphite range cooker with brass knobs is the de facto centrepiece of the kitchen… I wouldn’t want to detract from that.
Mirror, relatively easy to clean and makes the space look much bigger.
I didn't realise it was a thing, brother in law has a glass company and mentioned it was getting popular, Google it, it looks much better than it sounds :D
problem with tile splashback, which we have, is the grout is a pita to clean (toothbrush etc) .... maybe this would avoid that V
What exactly is Epoxy Grout?​
This epoxy material is primarily composed of epoxy resins combined with a filler powder, which chemically react with one another to form the epoxy grout material. This makes it waterproof and nearly stain-proof. Epoxy grout forms a strong seal between the tiles. Its durability makes it an excellent choice for splashbacks, floors, and high-traffic areas.
e: shiny splasbacks probably create bad reflections off of hob lights too
May be it was your post that was badly worded tbh hence my reply? i did say everyone had a budget so cost could be a factor. As for bling, I didn’t mention gold and copper isn’t shiny for long. Doubt brass colour would be either.
Couldn’t really make out your range within the darkness of the units in the render but I’m so you have it all worked out.
