- 7 Sep 2007
I currently have an older Asus extreme ii MB and 2x HD4890's in crossfire with 6gb of patriot memory and an i7 920 o/c to 4ghz.
Now I was looking at either of the following but does anyone know which was is th best way to go and why?
Option 1:
Keep my setup and simply get 2 new 7970's in crossfire using old pci-e 2.0 slots.
Option 2:
Get a new mother board that will have my i7 920 and can o/c again to 4ghz and above and maybe get 6gb or more memory so that the board has the new pci-e3.0 slots for the new cards and just get 1 hd 7970?
Or if anyone has any other idea's my budget is around £800 - £850 and want it to last a good few years to come.
I do have the cpu and both gfx cards watercooled so will be thinking about removing the water cooling for the cards as gpu blocks aint cheap and is a pain to drain when you want to upgrade. However I will obviously need watercooling still for my cpu as its o/c to 4ghz so may get a sealed loop with an external fan?
Then I can remove my double and tripple radiator and 2 pumps from the case as I think its all a bit of overkill.
Everyone's feedback is very much appreciated as I would like to get the most performance and future proof wise with my budget
Option 1:
Option 2:
