Cant think of anything else so i come for help from OcUK.
Basically the image here explains the problems:
Also:
I can not load image files into windows picture viewer like normal, they just wont open.
When i right click on song in Media Player and select 'Open File Location'... nothing happens.
Windows shutdown menu changes:
This has started recently but I cant think of anything which I have done to cause this problem. sometimes i can boot into windows with no problems at all. Sometimes the symptoms described appear after so long.
It is a real pain in the jaxie as you can probably imagine! And even more so having to reset the computer in hope that it will sort itself out.
I really cant explain it better than i have done. I am not very hopeful for a solution without a fresh install. But if anyone can help thankyou!
Also:
