Unusual problem with pc, overclock related?
12 Mar 2006
N.E England
Amd 3800+ 64 X2 LDBHE 0605FPMW Stepping @ 2.4ghz 240 x 10.0 1.35v
Asus A8R32-MVP Deluxe
Ati x1900xt 512mb Powercolor
1gb PC3200 Elixir 2x 512mb sticks dual channel running on divider of 166
Freezer 64
Hiper 580w Type-R Psu
Thermaltake Armor
now im running normal playing music downloading what have you, and it has done this when i turn off and on sometimes it will freeze and whatever music its playing, it will loop like a damaged cd would. Its done it when i turned it off the other day it hanged and loooped the turn off theme and did it when i turned it on like wise with the logging on windows theme i have tested the cpu on both cored for stability for 2 hours 15 before and found no errors on either core
anyone had similar problems, im running with the 0404 bios also could the cpu require more volts? temps are also fine 31 idle and 42 load
Hi, running at a A1N.O.S and prime95 so as it forces a overclock or 2451.5mhz with the 0404bios too. Tried playing music through WMP and internet yahoo music. My CPU gets to a nice and 'toasty' 51c but I have no sound issues...
ChrisC
hmm well i played around 1 and a half hours of oblivion before it hanged and did the exact same thing i guess this means my system is unstable? maybe i should increase the voltage slightly
