Upcoming 4k Gaming Monitor
26 Oct 2003
I was looking for a 4k 144hz monitor that has adequate brightness and 10bit color depth for quite some time. Unfortunately, these monitors are not very recent and not very satisfying.
You've got a few options, what size do you want though, 27/28" or 32" ? The Gigabyte M28U, Samsung Odyssey G7 S28, ASUS TUF 28" VG28UQL1A and LG 27GP950 are all well thought of options and will perform a bit better than the larger 32" size in terms of response times and motion clarity. At the larger end you've got the Gigabyte M32U which is the only really 'well' priced option if you want to spend more though the MSI 32" Optix MPG321UR QD is really well thought of and so is the ASUS ROG Swift 32" PG32UQ but you will pay several hundred pounds more for those and weather that is worth it to you is a question only you can really answer, what you gain with the extra cash is mostly just colour gammut, the MSI and Asus have a wider one.
Are you after more premium FALD monitor or standard edge illuminated?
And what's the usage?
