UPDATE Mysql/PHP Problem
4 Jul 2004
aberdeen
Hi
I have this code :
PHP:
mysql_connect($url,$username,$password);
@mysql_select_db($db) or die( "Unable to select database");
if (isset($_REQUEST['uid']))
$uidd = strip_tags($_REQUEST['uid']);
			  Header("Content-type: image/gif");
			  readfile('sample.gif');
  $test = '1';
while ($test == '1') {
	mysql_query("UPDATE counter SET hits=hits+1 WHERE uid = '$uidd'");
$test = 0;}
The $test while bit is just a test, to see if it loops more than once, which it doesn't.
Basically, it should update hits to hits + 1 yeh? Well ... it does hits + 2.
(ie, i go to the page with the image, it should add 1 to the hits, but instead it adds 2 every time. i cant work out why)
Any ideas?
BTW it *seems* to work fine if i take out the image bits (the header/read file lines).
Thanks.
And meh who needs security when you get no visits :p
But yeh, I know. I just couldn't be bothered to either find something that lets me make sure its an md5 hash, or remove any other sql commands.
But if anyone has any ideas???
Thanks
Actually ... even this still adds 2 each time ...
PHP:
<?php
$uidd = mysql_real_escape_string(strip_tags($_REQUEST['uid']));
Silly question.. but do you have the picture embedded twice on the same page?
btw, you don't need strip_tags on the uid, just mysql_real_escape_string, but if it is numerical only, then ctype_digit() would be better (a whitelist approach is always the best.)
No, I mean when you embed it in your (X)HTML with <img src="blah.php" /> do you have two of those?
The only reason that I can see, that it is updating twice is because the script is being called/invoked twice.
Also, to clear any semantics, change your SQL query to the 'proper' (strict) syntax using backticks (`) when you are identifying tables and columns:
Code:
UPDATE `counter` SET `hits` = `hits` + 1 WHERE `uid` = '$uuid'
Code:
Ah Isee what you mean. Well no, its only in the pages once, and i'vebeen mostly testing by putting the "image" (ie the php file) in the address bar, checking it that way. I'll change the mysql query to what you posted, in a min, see if that helps.
It works fine, without the image stuff (read file/header)
Thanks
Try this:
Code:
<?php
  /* can't echo/output/print text when providing img so just die() without message instead */
mysql_connect($url,$username,$password) or die();
mysql_select_db($db) or die();
if (isset($_REQUEST['uid'])) {
    static $uidd = mysql_real_escape_string($_GET['uid']); // change to POST or COOKIE if need be, but don't use REQUEST
    if ($uidd !== FALSE) {
    $uidd = FALSE;
