Right my motherboard seems to be failing so i need to update my rig was going to get a 2080ti as well but waiting until the one i want becomes available.
One thing i need to do is fit a drain to the loop as it currently does not have one. I am concerned with placement as my pump/reservoir for the drain as is it to high would i need to do it off the bottom rad.
Another thing i am concerned with is I am not sure i can find the allen key to bleed the top rad. I plan only to keep this setup for a month or so before i have to drain it and add my new 2080. So i wont be buying any mixed fluid until that point. Anyhow here is what the loop looks like. (this before finished but the layout is same)
And here is my current basket.
Any comments would be welcome quickly as i plan to hit buy by mid day at latest.
will add t connection.
