Updated my drivers games take longer to load and crash
29 Dec 2012
I have updated my graphics drivers to amd 16.11.5 games take longer to load and also crash after some 10 mins.
I Updated the drivers to 16.12.2 graphic got much better loaded a little quicker, I tested the game for about 1 hour before it crashed.
Update: Looks like its a issue with the latest AMD mantle, I switched to Direct X 11 and it works fine in ultra
Isn't Mantle nowadays not supported and not included in the drivers for 6 months now? What game you play using Mantle?
Dragon age 3 but it turns out that's not the issue, I dont know what it could be this only started happening after I updated the driver pack (driver and other software that comes with it)
Which were your previous drivers?
Because AMD has stopped developing Mantle since March 2015, and from 15.8 drivers onwards (August 2015) Dragon Age Inquisition is crashing and not "officially" supported by the developers regarding Mantle.
even using Direct X 11 im still having issues.
To tell you the truth I cant remember which drivers i was using, A message came up to update, I updated to Amd 16.11.5 which replaced all the old files (inc the other bit of software). This is when i started having issues, I asked on here switched to Direct X and updated to 16.12.2 which helped a little the game worked better but still crashes.
