Updating Android on Samsung Galaxy S2
24 Sep 2007
Hi Guys, sorry for the newb like question, but I have a Samsung Galaxy S2 currently running Android 2.3.3. Can this be updated to the latest version of Android, and if so, what are my chances if any of bricking the phone?
Thanks :cool:
You can do an "over the air" upgrade to 4.1.2, the last "officially" supported version by Samsung. This is a case of pressing a couple of buttons on the phone.
There are also a number of 3rd parties who have versions of Android as new as 4.4.4 (the current latest official release available from Google)
It would be recommended to do a factory reset even after doing the "over the air" (OTA) update, 2.3.3 to 4.1.2 is quite a big jump.
When installing a 3rd party ROM, you will be doing a full wipe anyway.
Always take a backup before you do anything. Your contacts should be backed up to Google (if you have your contacts still on your SIM, then get this changed ASAP), and you can back up text messages with something like SMS Backup & Restore.
As above, I would back up everything just in case. There should be an option to move all your contacts to your Google account in the contacts app.
I would also suggest perhaps installing Slimkat to the phone, I did it on my sister's S2 as she found the official Samsung 4.1.2 TouchWiz to be pretty slow and unreliable, and Slimkat made it feel like a completely new phone.
Also, make sure that the battery is quite high, like 60%+, because updating Android means that the firmware is also flashed.
As Touchwiz has been mentioned too, consider changing to another launcher. If you've used Litestep, Darkstep etc as shell replacements on Windows PCs, then the "launcher" is the phone's equivalent. Examples are Go Launcher, Nova and Apex.
