- 30 Sep 2006
- Midlands, UK
Hi all,
built a pc using:
Gigabyte GA-MA78GM-S2H
AMD 4450e
SATA Samsung Spinpoint SP2504c 250gb hdd
SATA Liteon DVDRW Lightscribe
2GB Corsair PC2 6400 ram
After formatting and installing Vista HP 32-bit, i loaded on the mobo drivers etc, did some windows updates and shut it down.
Took it home and booted it up and it just got stuck at the dos screen where it says "Updating DMI pool success........." or something like that.
Left it for ages but nothing happened. Except when i opened the dvd drive, thats when it booted up into windows.
Thinking it was a dodgy install, i totally reformatted and reinstalled windows. Same damn thing happens, every single time the pc boots up, either cold boot or a reset. The only way for it to progress is to open the dvd drive.
I've tried clearing the bios = no difference
I'm running bios version F3. There is only F4 that is more recent and it doesn't seem to pertain to my issue so i haven't bothered updating it.
I'm pretty sure the ram is ok, but i will have to test it to make sure
Can anybody offer any advice to this. I'm stumped as to why it only boots up when i press the eject button on the dvd drive.
Boot up order is:
dvd-rw
hdd
There is a more recent set of chipset drivers on the gigabyte site, which i tried downloading last night, but OMG there site has to be the slowest in the world. My 4mbit connection was downloading at 15KBps. It eventually bombed out.
There may also be a bios setting that i'm not aware of that may fix this.
But then, that's why i'm asking for help, cos i just don't know how to fix it!
Any help or advise would be very much appreciated, thanks
built a pc using:
AMD 4450e
Boot up order is:
dvd-rw
hdd
