- 2 Nov 2006
Hey guys
I am due to update my rig and was wondering if I could get your input.
After some research, I understand that my i5 2500K is still good and therefore I should (in principal) be able to retain it. I have detailed some of the key parts of my rig below:
- Gnward GeForce GTX 580 "GOOD Edition"
- Intel Core i5 2500K
- Asus P8Z68-V Pro MB (http://www.asus.com/uk/Motherboards/P8Z68V_PRO/)
- Noctua NH-D14 Dual Radiator CPU Cooler
- Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (got two in total, so 8GB)
- Windows 7
- Thermaltake 850w PSU (http://www.thinkcomputers.org/old/?x=reviews&id=855)
I plan to get two 970s in Sli and also the Asus ROC (1440p 144hz gsync one). I wanted to check whether:
(a) My CPU will be fine (oc’d to 4.5)
(b) My RAM (both speed and amount) will be fine
(c) There are any other potential issues or areas to improve
Thanks for all your help and comments in advance!
Neil
- Windows 7
Neil
