- 5 Aug 2006
- Kent, UK
Our home Internet access is via a 4G teltonika router with sim card. The aerial is on the roof above the chimney stack, then a 25 m SMA cable (it's two cables joined together) into the loft connected to the router.
There's now 5G signal available outside the house, so I'm thinking about upgrading our aerial and router to 5g. Whilst I'm doing that it seems like a good moment to think about better cable routing.
My questions:
1. Any recommendations for 5g routers? Our teltonika RUT 950 has been excellent so I'll probably just go with that brand again but there's a few models to chose from and I'm not sure what's best for my scenario.
2. Any recommendations for 5g aerials?
3. How much affect does the length of the SMA cable make on signal to noise ratio? Would it be better to have a short SMA cable but potentially have the router outside with an ethernet cable running into the house? Or have router inside the house but a long SMA cable with a join? There's a possibility I can reroute the SMA cable so that's it a shorter run into the loft and keep the router inside.
My questions:
