- 1 Jul 2015
Morning chaps,
Hopefully someone can give me a little advice.
I am looking to build a new system, that I can easily upgrade later when ca$h is a little more plentiful.
I want a gaming machine, but only have around £500 to spend right now. I'd like a rig that I can upgrade the GFx card later. For the short term the new system will only be required for work tasks (some development, general web browsing etc) and some minor gaming but in the long run I want to be able to upgrade the gfx card and turn it into a decent gaming PC.
I have a 4k monitor already, so don't need a screen but would like to use the full 4k capability later. I'd prefer 16gb RAM but could accept 8GB in the short term, I don't need a SSD as I have one in a dead laptop that I will swap over later, but will need some sort of HDD in the machine from day one.
Upgrade ability is the key point here,so if I go for lower ram I would like to be able to simply slot in another ram stick later instead of having to replace the whole lot. Also for the gfx card I'd either want a cheap one to start with or buy a semi decent one now and have the ability of linking the cards later via sli etc.
I have considered buying a cpu/mb combination that will give me some gfx onboard, but unsure if this would give me any basic gaming from day one.
I'm not that bothered about sound card upgrades, so onboard will probably be ok. I will need a decent wifi card from day one as I won't have access to a lan port in the short term, I will also require an external dvd drive. I have no strong opinion about AMD vs Intel so it's pretty much down to cost vs speed vs the ability to upgrade without replacing everything.
So anyone have any advice/links or could suggest a build for me?
Thanks in advance
Thanks in advance
