Upgrade Advice - 4 year old PC
21 Dec 2022
England
Hi,
I want to upgrade my PC however i don't know where to start, i would assume new graphics card....but have bottle necked old PCs that way.
CaseNZXT S340 MID TOWER GAMING CASE (BLACK/BLUE)
Processor (CPU)Intel® Core™i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
MotherboardASUS® PRIME Z370-P: ATX, LGA1151, USB 3.1, SATA 6GBs
Memory (RAM)16GB Corsair VENGEANCE DDR4 3000MHz (2 x 8GB)
Graphics Card8GB NVIDIA GEFORCE GTX 1080 - DVI, HDMI, 3x DP - GeForce GTX VR Ready!
1st M.2 SSD Drive256GB WD Black™ M.2 NVMe PCIe SSD (up to 2050MB/s R | 700MB/s W)
1st Storage Drive1TB WD BLACK 3.5" WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable1 x 1 Metre UK Power Cable (Kettle Lead)
Processor CoolingCorsair H100i V2 Hydro Series High Performance CPU Cooler
Thermal PasteSTANDARD THERMAL PASTE FOR SUFFICIENT COOLING
What do you do with your pc e.g gaming at what resoloution ?
Do you have your games stored on a ssd ?
The 8700k is still a solid gaming chip and not to far behind a ryzen 5600x
Thanks for your reponse!
I don't currently have the games stored on the SSD as it's so small.
I have 3 monitors, 1 is 2560x1440 the other 2 are standard 1080.
Also i have tried playing the new Call of Duty but it's way too stuttery.
What resoloution are you gaming at ? Are you on 1 monitor or using all 3 ?
Your PC looks fine apart from the GPU and SSD. Adding a second SATA SSD is trivial and cheap. So spend the money over that on a new GPU. The GTX 1080 is - very roughly - equivalent to a RTX 3060 so you're looking at the upper echelons of GPUs, which are quite costly.
Or you could just drop some of the graphics quality settings a notch.
