Hey looking for some advice upgrading my computer, here are my current specs
I7 930(Megahalems)
GIGABYTE-X58A-UD3R
XFX 5870
Kingston 6GB DDR3 1600Mhz
Corsair TX650W
Now i'd like to upgrade the graphics card to either Crossfire or just buy a new card, but i'm aware the card is pretty good on it's own although it does lack in the DX11 area.
I'd like to play BF3 on full graphics while also streaming it live using software capture, (justin.tv, xsplit broadcaster) Software capture takes a lot of FPS and cpu power i'm pretty much fine on the CPU as it's OC to 3.5-4Gz but what do you advise for the GPU, can this PSU handle 5870x2? or should i just get a newer card?
Also thinking of adding another 6gb ram but i'm guessing I should keep them the exact same types, not sure if the 650w can handle crossfire +12gb ram though
I7 930(Megahalems)
GIGABYTE-X58A-UD3R
XFX 5870
Corsair TX650W
