- 23 Mar 2011
Hi there! Recently upgraded from a 970 to a 1070 and its grea though i feel the rest of my system may be coming to the end of being relevent.
I have an i5 2500k at 4.5 ghz. This is under 100% load in bf1
8 gb ram not sure what brand but ddr3
Motherboard is asrock z68 extreme 4 gen 3 or something like that
Was toying with just upgrading ram but mobo only supports ddr3 so maybe in the long run that would be a wasted effort if i then upgrade the mobo to ddr4 down the line?
Main use for pc is gaming, would i need a new psu? I imagine if its fine now it should still be, xfx 650w if i recall.
Maybe a new case too
What should i be looking to spend. What is todays version of the 2500k? That had some staying power i must say
