Upgrade Advice for Newer Tech
12 May 2004
Dark Side of the Moon
I'm looking at upgrading my below spec. Its lasted well for the past 5 years and I can still play most games but even with SSD cards I'm finding the processing power is just a light pushed. I'd like to stay Intel as I find it more stable. Looking to spend upto £500, more if this is not enough and would like to keep the case, PSU and the RX 580. Any recommendations please?
I mainly use for gaming, such as COD Modern Warfare and Overwatch. Also use it for training, using virtual servers and video editing/rendering. I'd like to go water cooled but if expensive stay on air.
Current spec:
Antec 900 case
Corsair 600W PSU
Gigabyte GA-Z97X-UD3H-BK Black Edition
Avant 16Gb DDR3 RAM
Intel i7-4900K CPU 3.6Ghz
M.2 PCIE 500Gb SSD
Radeon RX580 8Gb
Thanks in advance!
The Intel platform isn't great to be honest. They're lagging behind AMD and if you invest now, you'll have no upgrade path. It's a dead platform.
You should be looking at AMD 3700x really but I would push an overclock on your CPU and upgrade the GPU. My 4790k is still going strong and probably will for a while longer and I recently upgraded to a 2070s,from a 980ti, with no complaints. Max usage while gaming is 65% on the cpu.
as above. a GPU will be you're best upgrade at the moment. that I7 should still be good for a little while longer. (im presuming you have a 4790k not a 4900k??)
Thanks Snips86x, I didn't realise Intel had fallen so far behind AMD. I new the Rysen CPU's were coming out but as I've previously had AMD's they were always less power than the Intels. Just shows how the mighty have fallen. I upgraded to the RX 580 last year because my HIS 7800 popped. Its was a good value GPU at the time. I might as well give this GPU to my son and treat myself.
And yes Joelk2, it is a 4790K, I just couldn't remember the exact number.
Snips86x, what timings are you using to get 4.7Ghz on your CPU? I'm at 4.0Ghz and stable?
