Hi Guys,
Thanks in advance for any advice and apologies if there is anything I should have done but have not done.
So I suppose the simple version of this story is I have a ga‑f2a78m‑hd2 (rev. 3.1) motherboard built PC I got from my brother, he was sold it as a gaming PC.
I have my doubts tbh, it has built in AMD graphics, windows 10 installed and a decent(ish) amount of RAM.
Think the processor is AMD A6-6400K, daresay that could/should be upgraded.
So it has a PCIE slot which I think I should use to upgrade gfx card or at least give it a dedicated graphics card.
This was supposed to be the simple version
So I guess what I'd be interested in knowing is what relatively cheap upgrades could I make to improve the machine. I'm interested in HD gaming but probably nowhere near top end.
(Also it there are any generous patrons out there who are willing to part with an older gfx card like. 1050 or 1050ti for a reasonable price I'd appreciate it, GPUs are very overpriced just now)
Just looking for general info and advice based on motherboard and what I could achieve with it. If you're bored give me a vest build and best bang for buck build.
Thanks guys and appreciate any help you can give.
