I'm looking to upgrade my graphics card for the new WoW expansion, as I realised the other day that my current setup (with a X1950XT) is only able to run the game at "fair" settings, which is no.2 on a scale from 1 to 6!
Current system is an Abit AW9D-Max motherboard, Core2 Duo E6400, 2Gb ram, X1950XT, Corsair HX520W psu.
I don't really play any other games than WoW on my PC - I use my PS3 for other games.
I was thinking of getting a GTX460 768Mb, but now I'm thinking I should perhaps go for an HD5770 1Gb. That way, if I need a performance boost I can crossfire with another 5770 on my mobo, and it's cheaper, although not quite as fast from what i've read.
Not 100% sure that my motherboard will run it though... the gfx cards are PCI-e 2.0, but I don't know whether my mobo is 2.0 or 1.1?
Can anyone tell me if the HD5770 will run ok in my system? And am I likely to be able to max out the graphics in WoW? (I know i could probably do with another 2Gb of ram)
Cheers!
Cheers!
