Hi there.
I don't usually venture outside of Motors but I'd like some input regarding some upgrades I want to perform to my PC. The build is about 3 years old now, and even back then it was a budget build and although its working nicely, I'm looking to get back into PC gaming a little bit more than I do now so I feel an upgrade is in order.
Specs
ATI (now AMD, when did that happen!?
) 4870 1GB
E5200 Overclocked @ 3.2Ghz
4GB PC6400
DFI P45 motherboard
1TB Harddrive X2
430W PSU
When I built that system I wasn't clued up too much on hardware back then, now I'm well behind and not really sure what sort of upgrades I should make.
I'd like to able to get playable frame rates on high/ultra settings at 1900x1080 on most games. Truth be told I can already manage this on most games with my CPU seemingly being what holds me back (I.E the reason I run my E5200 overclocked is because there is a noticeable frame rate difference between 2.5GHz and 3.2Ghz).
What sort of upgrades would you guys recommend?
Is it worth me staying on old tech and buying second hand, or should I just nuke this build and start again? There is not set budget, I'm just after cost effectiveness (But let's say I don't want to spend more than £400. I'm willing to buy s/h).
Any input is appreciated
Thanks
Josh
Specs
) 4870 1GBE5200 Overclocked @ 3.2Ghz
4GB PC6400
DFI P45 motherboard
1TB Harddrive X2
430W PSU
Thanks
Josh
