Upgrade advice Please. In two stages.
You may want to get a AM5 CPU contact frame (you can get a unbranded one for less than a tenner) as it fills the gaps in the AM5 CPU IHS and stops any thermal paste going down the sides of the CPU. Many of us use them but you do need to be careful fitting them as you have to remove the stock cpu holder around the socket. It's easy enough to do and is fine if you take your time.
Just got one, cheers.
