Hi guys its been over 3 years since I built my pc and my hard drive has just packed in so I am going to take this opportunity to upgrade. Heres the spec of my current PC:
Coolermaster Wavemaster Case
Antec True Blue 480W PSU
AMD Athlon XP2800+ Barton
2 x 512mb Corsair DDR CMX512-4000Pro 500mhz
Asus A7N8X-E Deluxe Motherboard
Maxtor 160GB + 250GB hard drives
WD MyBook 320GB
Sony DVD Writer
ATI 9800Pro
LG 1915s TFT
I am looking to upgrade Mobo, CPU, Ram and if necessary PSU and keep all the other bits (case, dvd drive, monitor etc.). I will probably also get a new hard drive.
Can anyone suggest some specs. I'm not looking for a gaming setup so the graphics card isnt important however I would prefer a graphics card rather than an onboard one. Is it best to go for the AMD Dual core or go for an Intel quad core? I havent kept an eye on the new processors so dont know whats best and the most affordable. Looking for about 2gb of ram minimum and would ideally like to spend no more than £250. Any suggestions and comments welcome. ]
Thanks
Glenn
WD MyBook 320GB
Sony DVD Writer
ATI 9800Pro
LG 1915s TFT
Thanks
Glenn
