Hi guys.
You lot were kind enough to help me out with some upgrade with my measly budget. I didn't get round to doing it then (Feb) due to a few bills etc.
Anyway, i need your help again please.
MY CURRENT SPEC :
CPU : Intel Core 2 Duo E6600 @ 3Ghz (overclocked).
RAM : 2GB Corsair Dominator Twin XMS2-6400.
HDD's : 150Gb Raptor For OS and Games & 74Gb Raptor for Demos & files.
GPU : EVGA Geforce 8800GTS superclocked 640Mb.
PSU : Hiper Type-R 580W.
Case : Antec 900.
CD/RW : Some random Hitachi thing.
Monitor : Samsung 245B (24" 1900x1200 Res).
MY BUDGET : £250-£300 MAX
THE PURPOSE OF UPGRADING :
Best bang for buck,
I only use my pc to play games and browse the net, i would like the fastest possible combination with my budget. I know its not a great budget but hopefully we can get a best bang for buck upgrade. Has to be able to play games at 1900x1200 res, framerates are very important.
Thank you so much for helping, it really is appreciated.
MY CURRENT SPEC :
Case : Antec 900.
Best bang for buck,
but just check if you require physX and CUDA
