Morning all!
My current system is as follows:
Gigabyte GA_965P_DS4 Mobo
Intel Core 2 Duo E6300 1.8Ghz - Currently Overclocked at 2.5 (but probably could go higher) with a Scythe Ninja cooler.
4 GB Geil RAM - 2GB initially then put more of what I thought was the same in, but now it appears I've got 2x PC2-5300 (333Mhz) and 2x PC2-6400 (400Mhz).
A 256MB X1800XT Graphics Card
SB Audigy
A Lian Li PC-7 Case with a Seasonic S12 430W Silent ATX2.0 Power Supply
250GB IDE Hard drive
Now I've been thinking of upgrading slightly -
I'd like to get a 5770 Graphics Card and a 1TB SATA HD and install windows 7 at the same time. I think I'd probably get a 650W PSU as well to run it all properly.
Two questions really
1 - Would buying the parts and slotting them in be worthwhile, or would it be like installing a V8 into an Austin Metro - a bit pointless without getting a whole new shooting match CPU, MOBO, RAM etc.
or
2 - Would everything work correctly and decently for a decent period without causing me problems?
Your advice is very much appreciated!
Thanks.
SB Audigy
or
Thanks.
