Hello,
I bought my PC from this good website four years ago and it's seen me through pretty much every game I've wanted up till now. I've just bought Civ V and found that my PC can't handle it, even on low settings.
I'm looking for an upgrade, I was thinking of getting a cheap couple of gig RAM plus a graphics card now and then a new main board, CPU and RAM later in the year.
But if any of you know a cheaper way, like is it possible to put a decent CPU in my current board, I'd be happy for the advice.
Also do you know if Win 7 will run on my sytem?
My specs are:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB)
Antec Sonata II Piano Black Quiet Case - 450W Smart Power PSU
Seagate Barracuda 7200.10 200GB ST3200820AS SATA-II 8MB Cache
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
Sapphire ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express)
GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit
My specs are:
Any DDR2-800 4gb kit will be perfect for your needs.
Warranty and after sales service is a whole different ball game. Now just a few weeks back a vendor who had offered a life time warranty stopped honoring any and all RMA's. So you take your chances with that side of things too. For me I have used most brands on the market. And I like some of the water cooled cards from EVGA, and Gigabyte because of the good service I have had in the past. But like I said at the end of the day they are all the same basically. Go for the one that is the best priced.
