Upgrade Advice Please!
26 Apr 2015
Hi,
Would appreciate some advice about upgrading the following system. Used foe games such as WOT, FSX, GTA V (once upgraded), BF4, Far Cry etc
My rig was bought in 2011 so probably needs a refresh, or would be interested to know if others think a complete new system:
Titan Spinosaur from OC
Intel i5-2500k 3.3 Ghz (Sandybridge) LGA1155
Gigabyte Z68X-UD3P Intel Z68 DDR3 Motherboard
OCZ Agility 3 60GB SSD
OcUK GeForce GTX570 1280MB GDDR5 PCI express graphics
Kingston HyperX Genesis 8GB DDR3 Memory (upgraded from 4GB originally)
22x DVDRW
Corsair Hydro H50-1 Luiquid CPU Cooler
Western Digital 500GB HDD
Xigmatek 120mmCrystal Purple LED Fan
XFX Pro 650W Core Edition Power Supply
I have overclocked to 4.4 GHz and works fine. I guess the obvious choice is to upgrade the GPU to maybe the GTX770 or 970, but I'm not particularly computer savvy so would appreciate advice please.
A GFX upgrade and a bigger SSD I think.
Is the board on the latest BIOS?
What budget do you have?
The 2500K is still a very relevant and decent CPU, especially with a nice overclock.
How would I check the BIOS? Sorry, as I said not particularly computer savvy. Budget is dependent on how long the upgrade would give me, up to £1000 for new system, maybe £300-£350 for upgrade?
Look in the BIOS or look at the memory tab of CPU-Z.
You just need a GFX card upgrade firstly, bigger 256GB SSD also to install the operating system and as many games as you can to.
Defiantly a bigger SSD and possibly a new GFX, I'd personally go for the Nvidia 970
But listen to Stulid, He's the king at system upgrades/specs :)
It most likely will need updating as the board pre-dates the GTX970 so may not "see" it till thats done.
It will mean you have to redo the overclock.
Use Qflash to do the update.
Download the file and extract the actual file to a USB stick, plug it in.
Restart the system, go into the BIOS, select Qflash and update from drive, point it to the file and hit go.
It does the update, power cycles, you go back into the BIOS and load failsafe defaults, then do the overclock again.
Do you know what case you have?
great, I'll do that, reset the OC and follow you guys advice. Is it worth OC again when the new SSD and GPU are added, or will it be fast enough anyway?
Do get the big SSD, as I just thought, GTAV is a bigger install size than your whole current SSD.
