Upgrade advice please!
19 Sep 2013
Back on 22nd September 2013 you nice people on this forum helped me source components for my build, totalling £955.
Rig is as below and my question to you once more is what do you recommend upgrading?
I wouldn't mind getting the machine VR ready as plan on buying first generation oculus rift on release so that is my driving force for upgrade. Budget is flexible, I don't need absolute cutting edge but don't want budget. Can also wait for upgrade if you think that's a better idea as on verge of big price drops due to next gen releases around corner.
Asus HD 7970 DirectCU II TOP 3072MB GDDR5 PCI-Express Graphics Card
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor
Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Samsung 120GB SSD 840 EVO SATA 6Gbs Basic - (MZ-7TE120BW)
Seasonic S12II 620W '80 Plus Bronze' Power Supply
Corsair Carbide 300R Mid Tower Case - Black
TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel
Noctua NH-U12P SE2 Dual Fan Quiet CPU Cooler
Seagate Barracuda 7200RPM 1TB SATA 6Gbs 64MB Cache - OEM (ST1000DM003) HDD
OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
Noiseblocker BlackSilent Pro Fan PL2 Fan - 120mm
Thanks for your help
