Upgrade advice please :).
17 Nov 2018
Just wondering what i should do next in terms of upgrading. Run a few MMO's & will be getting a few of the FPS games coming out in the near future.
Current rig
Intel i5 8400 4ghz
8gb ddr4 2400mhz
Tampa2 motherboard
NVIDIA GeForce GTX 1060 3gb
1tb sata hdd 7200rpm
250gb Samsung evo ssd
500w internal power supply
what should throw money into next for upgrading?
Thanks.
As mentioned, 16GB of RAM but try to get a matched set with a higher clockable speed.
Depending on budget, a larger SSD for faster reads and store the games on that. If you have additional, than the GPU as mentioned.
