Upgrade advice please
31 May 2006
Current set-up is:
  • ASUS Radeon RX 580 Dual 4GB
  • MSI B450 GAMING PLUS AMD Socket AM4 Motherboard
  • AMD Ryzen 5 3400G 3.7GHz Quad Core CPU
  • 32GB Crucial Ballistix Sport LT (4 x 8GB) DDR4-3200
Am I better looking to upgrade the CPU or graphics card for an improved gaming experience?
Thanks in advance!
Also depends what resolution your gaming at but stil the biggest upgrade would be a gpu as Mickyflinn mentioned above. If at 1080p then a cpu upgrade will also help.
Current set-up is:
Thanks in advance!
Both the CPU and the GPU, but you can upgrade the GPU as a higher priority, and then try to play at 3840x2160 which will move the CPU bottleneck to the GPU performance ceiling.
