Hi, almost four years ago I bought a "graphics workstation" from OC, and up until recently it has been genuinely good for my world of intensive photo editing, a bit of gaming, some work and being an argumentative git on social media. Full specs at the end to give an idea.
Now I'm hitting a couple of constraints, not the least of which is a terminal fear of opening a PC case and trying to fix something!
- The new AI features on Adobe image editing projects, most especially the DeNoise feature of Adobe Lightroom are stressing it out. I work with 50Mb RAW files and they can take minutes each to denoise. I feel pretty sure that the bottleneck is the graphics card (based on Internet reading and watching task manager while it was carrying out Denoise operations) so what's the best bang for buck upgrade I can get from my Palit GeForce RTX 2060 StormX 6144MB GDDR6 card? I wouldn't want to spend more than £500 unless there is a slightly more expensive option which comes with a significant premium. It seems both processing power and memory are important so a 12GB model looks essential.
- I'm drifting up towards capacity on the disks. Can I simply add more into this system or do I need to look at upgrading the existing ones?
- The one thing I am a bit surprised is that Microsoft seems to be telling me the system isn't Win 11 capable - does not support TPM 2.0. Looking online got me into the BIOS but the menu they suggested enabling it on had very different options to what was described. Should this system be capable? Maybe with a BIOS upgrade?
Sorry if this is a bit much but I wasn't sure where to ask these kind of questions but there seemed to be a lot of good advice in this forum. And if the answer really is "It's time to go for a new machine" then feel free to hit me with that too, I just think it really ought to be able to give me another couple of years with some upgrade TLC . . .
RENDA G4-CS Photography & Graphic Design Workstation -
Frequency Enhanced Intel Core i7K
CA-003-PT Phanteks Enthoo Pro Mid Tower Case - Black 1
CA-03A-KK Kolink Continuum 850W 80 Plus Platinum Modular Power Supply 1
CD-004-OK OcUK Value Blu-ray / DVDRW combi SATA - OEM 1
CM-000-KK Kolink Internal USB Hub - 60cm USB Cable 1
CM-027-TL Tech Labs Insulation 700x500x10mm base 1
CP-65L-IN Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - Retail 1
FG-063-NB System Build Fan - Noiseblocker BlackSilent Pro Fan PLPS - 120mm PWM (SI) [EXNO-001] 2
GX-04N-PL Palit GeForce RTX 2060 StormX 6144MB GDDR6 PCI-Express Graphics Card 1
HD-093-BT IcyBox Standard 5.25" Drive Bay USB 3.0 Multi Card Reader eSATA (IB-867) 1
HD-23Y-SA Samsung 970 EVO Plus Polaris 1TB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive 1
HD-23Z-SA Samsung 970 EVO Plus Polaris 2TB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive 1
HD-550-WD WD 4TB Black 7200RPM 256MB Cache Internal Performance Hard Drive (WD4005FZBX) 2
HS-044-AS Asetek Premium Retention Kit Intel LGA115X (35-150-0000014) 1
HS-04K-AS Asetek 240mm 670LT Thick Radiator (35-102-0000135) **PICK ONE SCREW BAG PER COOLER** 1
MB-6CU-AS Asus ROG Strix Z390-H Intel Z390 (Socket 1151) DDR4 ATX Motherboard 1
MY-08P-TG Team Group Vulcan T-Force 32GB (2x16GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD432G3 2
SW-172-MS Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139) 1
