Upgrade Advice Please
13 Sep 2024
Manchester
Looking at upgrading my son’s gaming pc. Games mostly played are BF6 and Avatar Fire and Ashes. About £1000 to spend, games will be played on 1440 IPS 180hz monitor.
Current spec
R5 7600
Gigabyte B650 Eagle AX DDR5 AM5 ATX MB
RX 7600 XT 16GB
Vengeance RGB EXPO 32GB ( 2x16 GB ) DDR5 PC5 48000C30
Asus TUF Gaming 850W 80 Plus Gold
Any advice greatly appreciated.
Thanks for your quick reply, just wondered is it a bad idea to blow the budget all on a gpu? Or would the R5 7600 bottle neck the gpu.
games like BF6 love X3D CPUs, you're better off with one than without
the reason is that this will help improve the minimum frame rates and games will feel less stuttery/janky
honestly the 5080 is only a 15%-ish improvement on the 5070ti/9070xt in rasterisation performance
i'd much rather have a 7800x3d/9800x3d + 5070ti/9070xt than a 7600 + 5080
Which 9070xt brand do you recommend? Thank you again for your help.
What heatsink are you running exactly? If it's the included Wraith stock cooler you should probably replace it, but almost anything else will be fine.
As above, bung these in (sans the HSF if not necessary) and jobs done, it'll be a night and day difference:
My basket at OcUK:
Total: £995.47 (includes delivery: £7.99)​
My basket at OcUK:
Forgot to mention the cooler is Thermalright Peerless Assassin 120 se ARGB. Case is a Kolink Observatory HF Mesh ARGB Midi tower.
lol prices have gone up, cheapest 9070xt is now PowerColor £589.99 on Overclockers website. should have done this post a bit earlier could have saved me £30.
For the sake of an extra £10 get the Asus, the PC Reaper is not a bad option but it's a two slot design (so smaller cooler) and has a history of iffy fans.
Honestly, I actually agree with @tamzzy when it comes to getting the cheapest of X or Y GPU, but there are instances where it's worth spending a little more.
