Yes a 5870 would be a better upgrade as it has more power, alternatively a 470 from NV would be on the same level, see whats in MM at the time
Hmm, So a 4870X2 or a 5870 for me I think then, or maybe a 560 TI if i can get one cheap.
Thanks for the advice!![]()
Wouldn't bother with the 4870X2 tbh it's old, hot running, not Direct X 11 and if you get any games that don't work with crossfire you're down to exactly the same performance as you have now!
Second hand 5870/5850 would be a much better idea, what's your budget? and what resolution do you game at?
Alright, thanks for the advice![]()
No probs, nice to see you took my advice on the 4870X2......Obviously had your heart set on one from the start lol![]()
Lets hope it doesn't come back to bite me in the ass like it always does for them
