Hello
Need some help with an upgrade, it's been a while since I did anything like this, so just need to know where best to spend my money. The budget is £150-200, I'm willing to go a little higher if there will be a large difference in performance.
I bought the PC without doing much research, foolish I know, about nine months ago and use it for photo editing mainly and general pc use. The outright processing power isn't fantastic it is enough, gets through 500 RAW images easily so I'm after better responsiveness. Just find the pc changing between programs sluggish, just generally slow, till it settles on a task.
Basically where is it best to spend my money, to improve the system responsiveness, is it graphics card, more ram, new motherboard, "overclock"?
If there is any additional info you needed for the best advice let me know. I paste the some of the specs below. Should mention I've gone through the startup setup etc to make sure there aren't any "extra" programs in the background so think it's about as fast as its' going to get.
Thanks
Processor Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Memory (RAM) 3.00 GB
Graphics ATI Radeon HD 2600 XT
Gaming graphics 1534 MB Total available graphics memory
Primary hard disk 44GB Free (456GB Total)
Windows Vista (TM) Home Premium
System
Manufacturer Dell Inc.
Model Inspiron 530
Total amount of system memory 3.00 GB RAM
System type 32-bit operating system
Number of processor cores 4
64-bit capable Yes
Storage
Total size of hard disk(s) 1397 GB
Disk partition (C
44 GB Free (456 GB Total)
Disk partition (D
5 GB Free (10 GB Total)
Media drive (E
CD/DVD
Media drive (L
CD/DVDCD/DVD
Disk partition (M
661 GB Free (932 GB Total)
Graphics
Display adapter type ATI Radeon HD 2600 XT
Total available graphics memory 1534 MB
Dedicated graphics memory 256 MB
Dedicated system memory 0 MB
Shared system memory 1278 MB
Display adapter driver version 8.402.0.0
Primary monitor resolution 1920x1200
DirectX version DirectX 10
Network
Network Adapter Intel(R) 82562V-2 10/100 Network Connection
Network Adapter Microsoft Tun Miniport Adapter
Network Adapter Bluetooth Device (Personal Area Network)
Network Adapter NETGEAR 108 Mbps Wireless PCI Adapter WG311T
Thanks
System
Model Inspiron 530
64-bit capable Yes
Storage
Disk partition (C
44 GB Free (456 GB Total) Disk partition (D
5 GB Free (10 GB Total) Media drive (E
CD/DVD Media drive (L
CD/DVDCD/DVD Disk partition (M
661 GB Free (932 GB Total) Graphics
Network
