upgrade advice
Permabanned
30 May 2006
newcastle
Is their a dual core board that supports sli. Ive got amd 4400 with asus kn8,ddr memory at the mo running 2 7900gts.I fancy the 6600 dual core but if no board does sli is it best jus to keep what ive got.cheers
Most of the Crossfire boards support SLI with older, hacked drivers.
The ASUS P5N2SLI and P5N32SLI SE both do SLi using the NVidia NForce chipsets. New ones - NForce 570, 590 and 680 are on their way apparently.
cheers ,is their much difference in performance....i wont be clocking n wots the prices or recommendations,?
