Upgrade advice.
24 Feb 2003
Porthcawl and Southampton
Looking for opinions really.
Main PC is abit an7 with athlon XP-M clocked up to 3400+(and above sometimes),or underclocked to keep consumption down depending on usage,
AGP Radeon 9700 128Mb.
I don't play games except for occasional flight sim, but do a fair bit of video editing/conversion and handling of large files from my digital SLR.
Been out of the loop for around 2yrs and now find that if I upgrade it'll need to be major. New graphics (PCI-e), RAM etc.
Money is not really an issue but percieved value for money is.
So the question is..shall I upgrade what I have or start from scratch. I only have 512Mb of Ram at the moment. Would 2x1Gb sticks work wonders for what I already have given my usage? Would a better AGP card help?
If I upgrade what I have then I'll also upgrade my media PC with a nice Silverstone case with VFD etc.
Any other suggestions?
A good dual core system is almost certainly the way to go, what is your budget here? I know you say it doesn't matter too much but a rough figure would help deciding what you could get for the money. :)
Hmm
e6300 + a/c 7 freezer
Asus P5B / Giga DS3/DS4
2gb geil pc6400
7600GT OC
anything along those lines and you will be far from disopointed
I've always been AMD in the past but it seems the Intel core duo is very popular.
Regarding budget it's a tricky one.
Say £400 quid for mobo, CPU/cooler and RAM. I already have a 250Gb IDE drive that I was going to slot into my system..which of course got me thinking of upgrades...now here I am!!!!
I hade previously not bothered with SATA...do you think I should?
a lot of new boards like the DS3 DS4 seem to only have 1 IDE slot, so if yo uhave a dvd writer that will use that slot to.
So maybe it's time to move to SATA?
One IDE port supports two devices though so it would be fine until ready to move to SATA. :)
Something like this ought to do you and although the motherboard won't be great for overclocking there is still a bit of potential.
MB-004-AK Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard (MB-004-AK)
£45.99 £45.99
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£99.99 £99.99
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.99 £14.99
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£139.99 £139.99
GX-040-OK OcUK GeForce 7300 GT 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail (GX-040-OK)
£49.99 £49.99
Subtotal £350.95
VAT £61.42
Total £412.37
£45.99 £45.99
£99.99 £99.99
£14.99 £14.99
£139.99 £139.99
£49.99 £49.99
Subtotal £350.95
VAT £61.42
Total £412.37
Ah true you me using the middle connector of the ribbon i take it?
Ben Cole said:
Thanks guys.
ASrock always had a bit of a bad name though IIRC..has their rep improved?
Well, to basically quote what I've said in another thread. ASRock are basically Asus' budget brand and they do offer a fair few innovative technologies(AGP and PCI-E on one board or DDR on a socket 775 motherboard), they aren't the most overclockable motherboards in the world but for half the price of most they aren't bad either. :)
Personally, i'd go for something like this:
Core2Duo E6300
Gigabyte DS3
Geil Value PC5300 2gb
X1300XT 256mb
Seagate Baracuda
Nec 4571
Lian-Li PC7+
Enermax Liberty 500w
This whole lot will only set you back around the £700 mark!
