Upgrade advice
27 Sep 2005
EDIT: a friend installed this cooler and recommended it, would this be a good choice?
Zalman CNPS9700-LED Aero Flower
My current system is as follows:
AMD 3200+ clocked to 2.6 (socket 939)
1gb dual channel matched pair OCZ Ram cas 2.5
2 x Sata 200gb
2 x BFG 7800 GT OC
Asus A8N Deluxe
Coolermaster Praetorian 730 (RC-730) Case
Akasa AK-913 EVO 33 Direct HeatPipe Copper with Fan Controller
I am upgrading in the next month with the following:
BFG GeForce 8800 GTS
AMD Athlon 64 X2 4800+ dual-core
2gb Dual Channel Matched Pair Ram Cas 2.5
I would like to note that I have no expereince overclocking and that my present system was overclocked by someone that knew what they were doing, so I would probably not overclock, and even if I did I wouldn't be pushing it that hard.
At the moment my Akaska cooler is very noisey when I am playing games as I have to turn it right up, is there a cooler that anyone would recommend that I put on the upgrade list I have.
Any advice would be great thank you.
Switch
