Upgrade advice
14 Oct 2004
location, location
Hi all,
It's been a long time since I last posted here, and I'm quite out of touch with the current PC market.
You can see my current spec in my signature. It's now about 3 years old (I think).
I'm considering an upgrade, and I'm fairly sure Intel is the way I want to go, but I know nothing about the current crop of motherboards. I'm not a serious overclocker, although I don't mind a little dabble.
I would really appreciate some advice on three options:
- £500 upgrade
- £750 upgrade
- £1000 upgrade
I would be looking for CPU, motherboard, RAM and ideally graphics, although the latter is not 100% essential it would be nice to get DX10. Also from the graphics point of view I'm an nVidia man all the way.
Thanks in advance to all who help :)
Hav
Above sounds about right.
But pitty about the Nvidia thing as they are getting a right spanking at the moment. The 4870 is the better choice.
If you have waited for 3 years and you're in no rush then I'd wait for the next batch of Intel processors such as the Core i7s - especially if you can stretch to 1k budget.
Yeah if you want the best performance i would wait for the I7's to mature a bit. Personally i favour bang for buck and imo thats still the 'current' gen architecture
Hi again all,
Thanks for the advice of those above.
I have tentatively selected the following:
Product Name Qty Price Line Total
EVGA GeForce GTX 260 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £179.99
(£211.49) £179.99
(£211.49)
Intel Core 2 Quad Pro Q6600 2.40GHz Guaranteed to run at 3.30GHZ (1466FSB) - Retail £139.99
(£164.49) £139.99
(£164.49)
Asus P5Q Pro Intel P45 (Socket 775) PCI-Express DDR2 Motherboard £79.99
(£93.99) £79.99
(£93.99)
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB) £59.99
(£70.49) £59.99
(£70.49)
Sub Total : £459.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £82.06
Total : £550.97
One quick question about the above. Is my ThermalRight SI-120 going to fit the Intel CPU, or will I need a hew HS? If so, could someone recommend one of a similar quality for the Intel CPU?
Thanks,
Hav
