Upgrade advice
16 Nov 2008
Hey guys, just a bit of advice needed :)
Looking to get a new Cpu, mobo, ram, PSU and graphics card...the thing is i haven't really upgraded in a long time so I dont really know what's the best I can get for my money. Have an Antec 300 and a 500gb Hard drive from my old rig so they should do fine.....Mainly going to use it for gaming...and can only spend at most around £380 or so, so I'm on a fairly tight budget. Would this be worth getting? Thanks
Your basketProduct Name Qty Price Line Total
OcUK GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card £109.99
(£91.66) £109.99
(£91.66)
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £94.99
(£79.16) £94.99
(£79.16)
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply £71.99
(£59.99) £71.99
(£59.99)
MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** £64.99
(£54.16) £64.99
(£54.16)
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
(£19.99) £23.99
(£19.99)
Sub Total : £304.96
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 20.00% VAT : £62.99
Total : £377.95
i3 2100 is massively faster while using less power.
Or you can easily get away with a 500W PSU, which means you can get a better GPU,
OcUK GeForce GTX 560 1024MB GDDR5 PCI-Express Graphics Card £134.99
(£112.49) £134.99
(£112.49)
(£79.16) £94.99
(£79.16)
(£54.16) £64.99
(£54.16)
Lepa W-Series 500W '80 Plus' Power Supply £46.99
(£39.16) £46.99
(£39.16)
(£19.99) £23.99
(£19.99)
Sub Total : £304.96
DPD Next Day Parcel
Total : £377.95
i3 2100 is dual core isnt it?...Would it be enough to play the likes of bad company 2 on fairly high graphics at a steady frame rate?
Dont get suckered into the whole "its only got two cores" thing.
The simple facts are its two cores (with hyperthreading also;)) are of a much newer design and this makes it faster than the old architecture of the Athlons and Phenoms.
For example - http://www.xbitlabs.com/articles/cpu/display/core-i3-2120-2100_5.html#sect0 -its clearly ahead of the Phenom955be, which unlike the Phenom850 has L3 cache memory, the Phenom850 is actually a Athlon core at a higher speed.
And the motherboard has SATA3.0 and USB3.0 and isnt a dead end socket like AM3 is.
