Hi
I'm looking to rebuild my current pc over the next few months but not sure what to do first.
These are the components I was thinking of getting:
i5 2500k
Gigabyte Z68AP-D3 Intel Z68
Kingston Hyperx Genesis Ram
Noctua NH-D14
NZXT Phantom Enthusiast (red/white)
Depending on which order I do it, 7970 if I order the GPU first or I'll see what Kepler brings if ordered last.
My current GPU is running at stock speeds and is hitting 81c when playing BF3. My case isn't the biggest and the gpu is a bit squashed between the psu and mobo, so I was thinking of getting the NZXT first. I'm not sure if I should get the cpu/mobo/ram or gpu, I want to be able to play BF3 on ultra so I was leaning towards getting a 7970 next.
My current psu is an Antec 620W, would this be enough to power an i5 2500k and 7970?
What would be the best order to purchase everything in?
Cheers
i5 2500k
Noctua NH-D14
Cheers
