Hi guys,
I am hoping to get some upgrade advice, I am a bit out of touch on the latest hardware.
I current rig is:
Asus P6X58D-E with a i7-960 running at 4ghz
Corsair XMS3 6 gig
680 GTX
M4 SSD
While I can build my own, I don't have allot of free time to tweak and stress test over the coming months, so was considering one of the pre-over clocked Bundles from ocuk, they do this day in and day out - far better than I can aswell!
Intel Core i7 3820 3.60GHz @ 4.40GHz CPU
Asus X79 Sabertooth Intel X79 (Socket 2011) DDR3 Motherboard
Corsair Vengeance Gold 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
http://www.overclockers.co.uk/showproduct.php?prodid=BU-117-OE&groupid=43&catid=2053&subcat=
or the
- CPU: Intel Core i7 3770K 3.50GHz @ 4.50GHz Ivybridge CPU
- Motherboard: Asus P8Z77-V Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Corsair Dominator 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel
http://www.overclockers.co.uk/showproduct.php?prodid=BU-115-OE&groupid=43&catid=2053&subcat=
Both look fairly solid, while I am not considering an SLI setup at the moment, it may be something I consider a year or so down the line. I mainly use this for games and basic working, nothing too demanding
I guess the first question, is it worth spending £600/700 on any of the current gear, is it going to be a significant improvement on what I have? Or am I being stupid and should just wait? (haswell it still some time away)
If you own any of the above/simular - how have you found it - worthwhile/any issues..etc?
Thank you in advance for any guidance or suggestions.
cheers,
I current rig is:
Corsair XMS3 6 gig
680 GTX
M4 SSD
or the
cheers,
